1988 OMC Cobra 5.7 loss of power
aleschef
I have a 1988 OMC Cobra 5.7 in my 23' Donzi Ragazza, the engine was rebuilt last year, along with a new outdrive. In neutral the engine runs great, sounds great, and has been tested by a mechanic. When in gear (under load) the engine seems to stutter and not run proper, if I touch the trim button the engine problem seems corrected??? This is some sore of electrical issue, I am stumped as are a couple boat mechanics I have seen. The grounds all seem to be proper, there is a new ignition switch, gauges all work. Any thoughts?
SeaTea
Check the ESA
Check the ESA
Since it stumbles in gear, you should check to make sure the transom shift cable is adjusted properly and the switches are not being activated when it is in gear. The rollers on the switches should be in the middle of the notches when in forward neutral or reverse, they only get activated while shifting. It stops when you push the trim switch because the power drain on the ESA will not allow it to work properly. Check the switches to ensure they are working and are not hanging up after activation.
Do not make any assumptions about the condition of the motor or drive, you should do a full diagnostic on the engine (compression check, static and full advance timing, check the condition of the plugs, check for proper carb float level, fuel pump pressure, non-ported vacuum reading at idle) as well as making sure all the shift mechanism is properly adjusted. There are many things that can cause your symptoms and you need more information, that's where the diagnostics come in.
Good luck and let us know what the problem was and the solution.
David K Hancock
Re: Check the ESA
Re: Check the ESA
I have a 1991 four wins 235 vista. Cobra stern drive and a 5.8 engine. I rebuilt the engine very shortly ago. New lowr end gears about a year ago. Thought I needed a shift cable. Due to back problems took it to a shop. They said three hindered to four. Yeah whatever. Anyway took boat out day I got it back everything fine. Took it out today week later, it will not go over 6 miles an hour. What could have happened?
