1988 Merc 220 xri...maybe a dumb fuel injector question?
dfrants
Got a 1988 Merc 220 xri thats running like its a 5 cylinder instead of a six. Spark is good but I think the #6 cylinder isn't getting fuel? Is this possible on a efi? Does each injector feed each cylinder? This will be my first time working on an efi so I'm alittle green...
Dukedog
injectors fire in pairs by ecu. 1 n 2, 3 n 4, 5 n 6.. if a single injector is suspect they should all be checked, cleaned and flow tested...
Faztbullet
Yep......also need to check compression as no fuel equals no lube to cylinder
dfrants
Are they difficult to replace? I found a different v-6 efi from the same year range that had an oil injection failure, but has 6 "good" fuel injectors?
Faztbullet
They are only good after they have been sent off,cleaned and flow balanced
