1988 Johnson V140hp
dirkstorm
I have a 1988 Johnson V140hp, has been sitting for many years. Emptied gas tank and put in new 97 octane, checked hoses for leaks, new plugs. When i turn the key, engine starts, idle rpm low, then engine starts to "buck", lot of smoke. Any suggestions?
schematic
likely burning off accumulated oil in carbs. Drain carbs and try again. If still smokes badly after a few minutes, look for fuel restriction
emdsapmgr
You may need to pull the carbs apart for a thorough cleaning. If one or more of the jets is restricted with debris, that can affect the idle. Further, if one or more of the jets is restricted, the engine may not be getting enough fuel/lube oil as it runs. Trying to run it with a restriction could lead to powerhead damage..
James R
A motor in this condition needs a complete carb rebuild, fresh fuel and the lower unit serviced before even attempting to run it and run on 50:1 mix until the oiling system is proven. That is of course if it has an oiling system. Emdsapmgr is absolutely correct. If you want a blown motor do as you are doing. 97 octane is a no no. This motor needs 87 not more unless you want to do additional damage.
Of course before spending the money it would be a good idea to check the compressions to see if you have something to worfk with.
