philForce85
Thread starter- Joined
- Jul 31, 2014
- 6
I bought this boat last summer and the guy said he had some issues with the key switch but he started it to demo it and it did run.
so I had a look and the key switch was bad for sure. I picked up an after market switch and it is a bit different.
The original switch had an option to push the key when cranking to activat the choke so I put a switch from the ignition terminal ( Yellow with red stripe) so I turn the key to the cranking position and if the switch is on it chokes too.
Nowit cranks ok but it wont' start. I found wiring info that shows how the wires go to the switch but nothing that actually shows how the switch works.
the wires back at the terminal block on the motor are as such:
1 - starter - yellow
2 - regulator rectifier (tach) purple
3 - CO-unit - white
4 - choke - green
5 - orange (heat sensor for buzzer)
6 - Red wire to bat +
7- CO unit blue
8 - ground - black
wire 7 isn't actually present on the terminal block, that and the orange aren't going anywhere but shouldn't be needed to start the motor, later I can play with the heat sensor buzzer thing but I'd like to start it.
looking at the back of the original key switch I have 6 terminals
going clockwise starting at the hot wire
1 - red - hot
2 - white CO Unit - marked M on old key
3 - blue - CO Unit - marked M on old key
4 - this terminal not use ( even on the schematic)
4 - yellow - starter motor (solenoid)
5 - green - choke
so I need the red, that\s power, if I connect that to the green, I should get choke. I can do that through a separate switch..
Red to yellow makes the motor crank.
All that is left is the white and the blue and both go to C0 -unit it is marked M for magneto I guess on the back of the key. If it were an old car it would just make the coil hot but these two wires have me stumped.
Can I assume that these wires, if joined will act as a kill switch? or should one of those see power in order for the ignition to get a spark?
It seems like I have it cranking but not firing and I suspect the ignition - no spark (hard to check myself) I opened the old switch but the switch wasn't in good enough shape to figure out how those last two wires should be influenced by the key switch.
Obviously I should order a new key switch but I think if I could just understand how it should work I should be able to wire around the issue that my off the shelf key is a bit different.
if I could just get this one last piece of the puzzle solved I would have a much better weekend. I have been fixing other issues on it for a week solid ( i did some fiberglass patching rebuilt surge brake system, etc) I really want to take it for a spin. Any help would be greatly appreciated.
3 - CO-unit - white
4 - choke - green
7- CO unit blue
8 - ground - black
1 - red - hot
5 - green - choke
