1988 Force 85 hp
mauiboy
A dealer told me that on power pacs it is best to buy both of them instead of one be cause the older one will burn out the new one is this true
shytownborn
Re: 1988 Force 85 hp
ive, mixed and matched, old with new, the black mods with the blues, never have a problem
MWBROWN
Me too. No problems.
Been over a year.
Frank Acampora
Dealer is just trying to Take more money from you. Those power packs (CD Boxes) Have separate power supplies and are not interconnected. One will not blow out the other if they are correctly installed.
mauiboy
Thanks guys
So you can mix black ones with the blue and from what years will I need to look at will a 1984 work with a 1988 power pack
Frank Acampora
You can mix black CD boxes with blue, but I have read in other threads that you can not mix colors between boxes and coils--that is blue coils with black boxes and reverse. I have also read that certain stators will not function correctly with certain color CD boxes--I forget the particulars on that one though.
I did mix a black box and blue coil and blue box with black coil on a 1990 90 (I bought it like that) It did last only 2 seasons for me before having ignition problems. Was it the different colored components or just normal age? I could not tell you.
As far as years, from 1982 on they were all the same electronics. BUT, from 1982 to (I think) 1984, the ignition components were wired with quick-connect fittings. Later ones were wired with a terminal board on the CD box and coil plate. So, for example, if you were to buy an earlier CD box, you would need to cut off the connectors and crimp on spade or ring terminals.
mauiboy
Thanks Frank
Thats why I like this forums it gives guys like me good answers
