1988 force 85 choke solenoid ?
mauiboy
My 1988 85 hp seems to try to ingage but dont the slug looks clean and I can push it in with ease the motor turns over so the batt is strong is there away to rebuild the solenoid or do i need to replace it.
Barnacle_Bill
Re: 1988 force 85 choke solenoid ?
If your solenoid is bad it needs to be replaced. They are only about $25
mauiboy
thaks I found out that my batt had power to start the motor but I guss not enough to power the solenoid batt was at 75% after charging batt solenoid worked.
