jimbowie85
Thread starter- Joined
- Jul 29, 2007
- 2
I have a force 125 1988 lower unit siezed up. can anyone tell me what year and hp models will interchange with my motor. model #1253X8C ser. # 1094.
thanks frank . so nothing after 1988 will work? also im new to boating what is WOT?Almost any one piece lower unit from late Chrysler up tp 88 Force three or four cylinder engine will fit; they never changed the drive shaft, gearcase, or internals. Everything just bolts right up. The only changes were the shape of the skeg. If you use a lower unit from an 85 Horse Force, check it by spinning the drive shaft and see how many turns it takes to turn the prop shaft one turn. On most, the gear ratio is 2-1 rather than the 1.78 to 1 of your lower unit. You will need to use a prop with about 2 in pitch more. The upside is that you will gain about 2 MPH. The downside is that you will use more gas at WOT.
