1988 Evinrude 28 SPL Losing Fuel Prime
6t7gto
Request Advice - When trolling at idle or at idle in neutral, the engine loses fuel prime after a few minutes and dies. If I frequently squeeze the primer bulb it stays running forever. A hair over idle and there is no problem. I have changed the fittings on both ends of the fuel hose as well as the primer bulb. I inspected all hoses from the engine fitting to the fuel pump and find all tight and with no evidence of leaks. I took the fuel pump apart and everything "looks" fine. The engine runs great through the RPM's.<br /><br />Thanks for your help!!
