Hello guys,
About a year ago I took the 1988 evinrude 120hp looper off the transom of our boat to replace a steering cable. Due to impending bad weather, I removed all cables from it so I could store the engine in the garage while I waited for parts. After finally getting it back together, and water testing it, we have 2 problems that have both shown up since removing the motor from the transom (yes it took me a year to put it back together due to life getting in the way)
First, the motor is slow to accelerate. to be specific, when you go to full throttle, the motor acts like it is only at 1/4 throttle for about 20 seconds, then takes off like the throttle is fully open. I have no idea where to start with this problem.
The second problem is that on plane, the gearbox has started jumping out of gear and back in. feels like the motor hits something momentarily. We had the problem about 4 years ago, the lower ring that engages the gear in the lower leg and the gear that it engages were stuffed (common problem I am told). we replaced it with a low hour second hand lower unit, and had problem free up until the motor was removed from the transom.
Is this just bad luck that it's failed in the same way, could it be an adjustment that needs doing? if it is an adjustment, will the fact it's popping out already mean the leg is damaged now? is there an upgrade or an aftermarket solution to eliminate this problem happening again?
Adam
Adam
