1988 35 hp doesn't seem to want to shift
The Force power
Your going to need a manual and tools from drivers to pullers (some can be "home made") to complete this task.
That small piece you're talking about sits on the drive-shaft in the water pump area
The shims would sit between the bearing-carrier and the LU (inside) to ensure the right amount of backlash
Tooth contact pattern is as important if not more important than " backlash " in my opinion.
