1988 100GT Johnson refurb.
James R
This is a J100STLCCA. I have the new decals but don't have a pic to show me how they sit.
Does anyone have a pic of this motor.
Thanks.
Jim.
emdsapmgr
This may be an 89... Just Google your engine and look through all the pics.
James R
Thanks emdsapmgr. One additional question. The decals i have are OEM are they applied in the same manner as the aftermarket Vinyl decals or is there another technique.
emdsapmgr
If you are working with a small, single decal,you can put it on by hand. On larger decals, like yours, I'd probably put them on wet, then squeegee the moisture out and let them set overnight. That's me, a non-decal expert that needs a little wiggle room when applying them. I've seen many experts just put them on dry-first time-in perfect alignment.
gm280
I guess that really depends on the type of the decal. If the decal isn't supposed to be applied via water, then you have to use the backing and start at one side and slowly apply while working the backing off and work any bubbles out as you go. But it is a one shot deal. So make certain you have it aligned exactly where and how you want it before starting. JMHO
James R
gm280 your point raises the question, can these OEM decals be applied with water or must they be applied dry?
At $65 a shot I don't want to mess up.
James R
Motor repainted with auto paint matched to original color and clear coated. Used soapy water to help put the decals on. Looks nice.
Thanks for every ones help.
