1987 mercury 75hp 4 cyl manual or timing specs
10Rams
Hello. Buttoning up an engine I bought. Putting new stator and trigger on it and figured I should check timing afterwards. Any chance of a manual or timing specs? 0b109100 is serial number. TIA!
Faztbullet
Max Timing at cranking speed: 30°
Max Timing running: 27°
Pick up timing: 3-4 °
No idle timing
10Rams
No idle timing
You’re the man! Thanks! I’m waiting for my stator to come in. I’ve went ahead and made sure my pointer timer was on point and correct at .464 in the mean time. I’m newer to this older outboard stuff what exactly and how do you set the pick up timing?
