1987 Johnson 150 GT fuel restriction alarm??
Fed
Worrying about air leaks & fuel pumps is only taking your eye off the ball.
Something is blocking the fuel before the point where the tank connects to the fuel line.
MMarshall88
Yep. I have to figure it out. I'm gonna look at getting a tank this week and take the boat out on and try it.
MMarshall88
I took the boat out over the weekend. Before I did, I was reading some other forums and was thinking about the pickup tube in my gas tank. I took the gas tank out again and completely drained it. There were some trash and small particles in the bottom also looked like a leaf or something it there. I went to the store and bought some cleaner and foam stuff and I sprayed it in the tank. I let it set for 15 minutes and I filled the tank up with water and rinsed it out. Sounds like a bad idea but I was able to clean it out good. I let it air dry until dry and then I put a fan into it to make sure it was dry. Then I added some fuel treatment and some gas inside and mixed it around and drained it again. I then proceeded to add a new fuel hose in there. The only hose I could get to attach to the fitting and run down in the tank was a 1/4 inch hose. Nothing else would work. It was all to big. I let the hose longer so that it would lay in the bottom of the tank instead of run straight down into it. I went and put about 15 gallons in it and went to the lake. I also carried with me a spare tank with fuel in it. I rode around for a long time. I even fished some and rode the boat back and forth up and down the lake. I made sharp turns trying to get the alarm to sound and for the bubble to flatten, but I never could. Hopefully I have fixed the problem. Only thing is that the new hose doesn't have a screen on it. Would that seem to cause problems??? I have a fuel filter on it. I've heard of people putting 2 filter on a motor. So not sure.
emdsapmgr
You are going to have to pull the fuel pickup out again. That engine (any V6) needs to run on 3/8 fuel hose. Even the V4 engines run on 5/16" hose. Best to replace that 1/4" fuel pickup hose before it caused a lean fuel situation.
MMarshall88
Well it was really weird. The hose I took out was the exact same size that I put back in. Yea I read that the motor takes 3/8 hose. But if I try to get a 3/8 hose or 5/16 to it. It won't run through the hole to attach the fitting. It's a older tank. I'm sure the newer tanks are diff. I don't know how else to get a bigger hose on it. When I take the sender unit out, my hand is to big to stick inside the hole to attach the hose to the fitting that way. I have to connect the hose to the fitting and feed it through the hole into the tank. The hole is threaded so I have hardly any room to even get the 1/4 hose into there. Not sure what else to do.
emdsapmgr
Most fuel pickups are a sort of a clear plastic. They have a very thin wall. That way the outer diameter is not much bigger than the 3/8 I.D. Your normal black fuel hose is much thicker walled and is presenting you with the problem. I know most all boat shops sell replacement fuel pickups (with tube pickups) most size tanks. Just cut the clear plastic hose to the length you need for your tank. A better solution.
