1987 Force 125HP
lushka16
My motor has been problematic from the start, and it seems to have basically the same problems as everyone else. <br /><br />I can pull a tube, but it takes a while to get up to speed. <br /><br />Skiers are touch and go, up on 2 skiis is fine just takes a while to get to speed, one ski forget about it if the skiier is over 130 pounds. <br /><br />It seems that my top speed is about 30 MPH @ 4000 RPMS, I can coax 4500 with the trim. <br /><br />I have replaced the spark plugs, played with the mixture, cleaned the carb.. I did other things, but I can't really remember what. <br /><br />Here's the wierd thing though - I can "trick" the motor into gaining speed by turning right really sharply. Does this have any significance? <br /><br />I've been getting really random performance from different props. 15 17 and 13.. they seem to work better at random.<br />Thanks a lot<br />Elia
WillyBWright
Re: 1987 Force 125HP
Me thinks you have a problem that needs repair. Could be just about anything. I'm thinking you're not getting full horsepower out of one or more cylinders.
roscoe
Yes, its time for a compression check. Then check for spark to each cylinder. If you have spark, then decarb the engine. Then check compression again.
lushka16
Great, I'm just trying to get a list together of things I want to do once it gets a little warmer. <br />So right now it's spark and compression. Anything else?
OBJ
Well...let me throw this out. Lushka, tell us about how the rig is set up. Where is the anti-cavitation plate in regards to the keel? If you have Trim N' Tilt, do you use it? I mean is the engine trimmed all the way in coming out of the hole and then trimmed with the rig coming up.<br /><br />Just taking a shot in the dark here. :)
