1987 80HP Mercury
ItsJrock
Hello,
I have a 1987 Mercury 80HP 3CYL engine on a 16ft skeeter bass boat. There are a couple issues with the the motor,
1. The engine misfires when coming off plane, at about 3000RPM, the boat starts to misfire terribly. I put it in neutral and it goes away.. I'm thinking stater.
2. Serial Numbers... The one on the engine says A727384 but I CANNOT find anything online about this model of engine. The only model i can find is A722297.
Any Ideas about number the Serial number? I also think that replacing the stater will fix this because i have rebuild the ENTIRE fuel system, plugs are good, compression is at 120 on all 3 CYL good spark. i have done a trigger and coils. My Voltmeter tells me that at about 5500RPM's the boat is charging at 18V.
Thanks
flyingscott
Canadian 1987 model 80 hp. If you have an unregulated charging system your voltages will be higher but they usually top out at about 16 volts. Have you done a link and sync.
801987ELOA966142 - B240450A722297
801988ELPTOB240451 - C099999A730007
