Help 70 hp 1987 yamaha overheat at low rpms
Oil breather. Thermostat. Thermo switch changed. jb welded a small leak near zinc anode at cylinder block.. Water impeller and water housing chnaged
2000 rpm or more runs good
Trolls at 850 to 900 rpms
Compression. 90 90 95
Top speed 38 mph
Buzzer does not work
Old impeller had all of its teeth so no parts in engine.
When at home testing with muffs or in large bucket of water. Engine does not overheat. Rpms around 2200.
How do I fix this problem. Overheat if less than 1800 rpms. seems when under load will overheat in 10 minutes.
Top speed 38 mph
