1987 50 hp johnson will this lower unit fit
fpctim
could anyone tell me if this will fit my 1987 50 hp johnson EVINRUDE JOHNSON LOWER UNIT OUTBOARD web page ebay
rickdb1boat
Re: 1987 50 hp johnson will this lower unit fit
Tim<br />Do you have a short shaft now? Also, it says from '73-'77, so I doubt it!
fpctim
im sorry to say this but i dont know how do i tell
rickdb1boat
Maybe this will help, <br /><br />
fpctim
its like 15 or 16 inchs
rickdb1boat
Tim<br />Then it's a short shaft 15". Keep looking on E-Bay and one will come along. There is one guy on there that says he has lots of them. Might try to contact him and see if he has one that will fit.
dpmpat
The years of coverage are not correct. from 73 to about 75 they used a hydro-assist lower unit. Thes can be determined by rotating the driveshaft clockwise and viewing the rotation of the prop shaft. With the shift shaft pulled up all the way, a clockwise rotation of the driveshaft will cause a clockwise rotation of the prop(foward). This is the one that you want. The earlier versions of your lower unit(non-hydro) will work, but the impeller is different it uses a half moon key instead of a pin or cam. Also, the foward gear uses a tapered roller bearing instead of a roller thrust bearing. I prob' have one in short shaft, but would like to confirm with a mod. number. I may have some repair parts too, as I have owned a few of these and have spares lying around. E-mail me at sdonovan1@mn.rr.com if interested
S.T. Marine
fpctim: I have a lower unit from a 1988 that will bolt up to your motor. It is 15" if interested e mail me at Stmarine@hotmail.com<br /><br />thanks
