1987 225 Johnson water tubes
smurfsideresort
Can I see the water tubes by removing the 2 side plates just above the lower unit near the steering pivot. I have cold water gushing out at the steering pivot and am getting some in the lower unit. My thoughts are that the tube from the pump to the head is split (cold water) and the seal on the drive-shaft just can't handle the amount of water that is in the housing.
93bronco
Ensign
Re: 1987 225 Johnson water tubes
no you cant see them through those plate. they are just covers for the mounts. <and to help keep them in place>
