1987 110hp Evinrude Fuel/Oil leak
bullpin29
I have a 1987 110 HP VRO THAT RUNS GOOD AT ALL RPMS BUT IT HAS A FUEL/OIL MIXTURE LEAKING OUT BELOW THE COWL. I GUESS IT IS A SEAL PROBLEM WITH THE CRANKCASE BUT WHERE DO I BEGIN TO LOOK.
Dhadley
Re: 1987 110hp Evinrude Fuel/Oil leak
There is a small drain hose that goes from the bottom port side of the air silencer base to the block. Look and see if its off or damaged.<br /><br />Good luck and stop yelling! Lol!
bullpin29
Thanks Dhadley I will look for that line and get back to you.
Dhadley
We'll be here.<br /><br />Good luck!
