Hello
I recently replaced the impeller after hitting a sand bar and sucking up a bunch of junk. The old impeller was distroyed. I found some of the pieces and made sure water flows through the system.
I can put the muffs on and get it to pump but not from a large container (bucket) or the lake. I know there is am air leak somewhere. I have check all the conections back to the point where it gose into the out drive ( S Hose). Could someone give me a hint?
Also...I clamped in a garden hose to the inlet side of the pump and water will go through the system without the motor running. Is that normal?
Thanks
Mark
Thanks
Mark
