1986 two 1979 Johnson Tilt/Trim Wiring (help)
navigatorvictory
My 1986 110 motor crapped out and I bought a 1979 115 I had to use the jack plate and hydrolic from the 86 on the 79 as the 79 had a cracked plate. These parts interchanged easy but apparently the wiring changed.....
First pic is from 79 jack plate has a blue wire green wire and then two what look like black wires but on the ends one looks like it is supposed to be read the other pic is the wiring harness from the boat to the motor which did plug into the 86 but, there is nowhere to plug it into the 79 was wondering what the different colored wires went to and maybe I can figure out how to tap into other wires?
Final pic is of all the wires ones from boat to 86 motor and wires that are on 79 motor I am sure there is a way to wire them together but, I do not want to burn anything up....thanks for any and all help in advance
<a href="http://s127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/?action=view&current=IMG_1512.jpg" target="_blank"><img src="http://i127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/IMG_1512.jpg" border="0" alt="Photobucket"></a>
<a href="http://s127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/?action=view&current=IMG_1513.jpg" target="_blank"><img src="http://i127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/IMG_1513.jpg" border="0" alt="Photobucket"></a>
<a href="http://s127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/?action=view&current=IMG_1514-1.jpg" target="_blank"><img src="http://i127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/IMG_1514-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/?action=view&current=IMG_1515.jpg" target="_blank"><img src="http://i127.photobucket.com/albums/p143/navigatorvictory/boat%20wires/IMG_1515.jpg" border="0" alt="Photobucket"></a>
Boatist
Re: 1986 two 1979 Johnson Tilt/Trim Wiring (help)
I would repost in the Johnson motor section or get them to move it there.
