1986 Johnson 20 hp = tiller = stop button conversion to kill cord
Camsmith56
Hey,
Long time reader but first time poster.
I thought I did a pretty thorough search for this particular topic but could not find any specific info on this particular make and model.
I have a 1986 Johnson 20hp tiller steer with a stop button at the very end of the tiller.
I wanted to covert the stop button to a kill cord switch, so that i can connect a kill cord and should be a lot safer when riding solo.
I found the envinrude/johnson part # 0398692 for a new kill cord switch that appears to fit the motor I have.
This is about $130.
This seems like a project i could do myself.
Appears you just disassemble to tiller handle throttle, remove the old stop switch....
Then, there are 2 wires to cut and then the new kill cord switch has 2 wires as well, that you just connect back together.
Then re-assemble.
Anyone out there have a schematic of the tiller handle so i know i can take apart and re-assemble in the correct manner??
thanks,
Honorary Supreme Mariner
You will learn some new words taking the handle apart.----Put the kill switch anywhere on the motor cowling or in the boat.----Wire it in to the wires from the stop button.
