1986 Bayliner Capri 125hp Force
Torch
Does anyone know which terminal the tach connects to on the ignition switch? I tried once, but bled the battery down, so disconnected it!!! :confused:
Torch
Re: 1986 Bayliner Capri 125hp Force
well yes on the Tach, but what about the ignition switch..........which terminal there????
tater76
One of the M terminals
TMALEGA
On my ignition switch there is a terminal that only has power going to it when the key is on. I use that one so it would not be on when the engine is off. I believe it was the i terminal. I was also told by many people on here that it is the one it should be used on , the m if i remember correctly is for the magneto and controls on or off for the motor. Depending on the set up if the m circuit is open it will run on others if it is closed it will run and reverse to shut off the engine. Hope this helps.
jerryjerry05
Usually the grey lead(maybe).Purple is the power to all the guages.
