I have a 1986' 85hp Force Engine and after many years of good use I've run into a few problems that I am having a problem troubleshooting. <br />1st) there are 3 carbs stacked on top of one another and I believe the lower carb is for the idle. The engine wouldn't start/idle so I adjusted each carb and i think i made it worse. What is the correct carb adjustment (how many screw-turn adjustments for each carb?)? <br />2nd) I've noticed a milky white substance coming from the carburetors that I beleive is water mixing with the 2 cycle fuel...where do i begin and is this the reason the boat all of a sudden won't idle??<br />3rd) Where can I find a water pump and fuel pump for this seemingly obsolete engine???
