1986 25hp Yam. ESJ no spark
cheesehead4
Please give some troubleshooting tips on this. (year, hp, model .. 86 25-ESJ)
Both plugs no spark. Safety switch is fine. It's not been run for almost 1 year and ran very good then. I've got a nice DVM but am unsure of various readings I should have at various components.
99yam40
Re: 1986 25hp Yam. ESJ no spark
Sorry, I have not worked on that old of a Yamaha so I do not know the components of the ignition system .
A manual for your motor will give the necessary info of how and what, but I believe you will need a DVA adapter for your DVM or the right peak reading voltmeter to read the peak voltages if it is like the newer ones .
Ru4rusty2
Get A DVA (Peak Reading Voltage) Adapter for your multimeter
When testing for Resistance (Ohms) Unhook The Battery
DVA tests should be done whlie cranking
Stator test
Brown to blue should read 120-150 Ohms
DVA should read 190v
Multimeter should be set to DC volts when using the DVA adapter
Trigger Test
Black to White/Red and Black to White/Black Should read 12-16 Ohms
Dva Should read 5v
Ignition Coils
Most Yamaha Plug wires are glued into the Ignition Coils so if you haven't already pulled them off. don't
Black to Black/White Primary Coil should read 0.5 Ohms +/- 10%
Black to end of plug wire Secondary Coil should read 3.5 Kilohms +/- 10%
CDI output Should be around 210v
Hope this helps
Chris
cheesehead4
My meter is a Fluke 115 true RMS. It has a min/max button.
Is this what you are talking about to record voltage peaks?
cheesehead4
At the river last week dead on the dock no spark. Pulled and prodded at all electrical stuff. Everything looked fine.
Crazy thing............. I assemble all the right gear to check this electrical problem. Today hit key in preparation for some diagnostic info and it fires right up. Can't fix what's not broken. Thanks for help. I'll post again should it quit with info.
