1986 235hp Johnson
kim
Does anyone know how much compreshion that this motor should have?
Dhadley
Re: 1986 235hp Johnson
It depends on which heads are on it. As long as the compression is equal within 15 lbs it should be fine. Does it idle OK?<br /><br />Good luck!
round2it
Don't know if ur having problems or not, but this would be a good time to check water flow around cyl. My 82, 235 ran great, but water flow around top right bank was blocked by flattened water diverters. Caused the cylinder to overheat and fragmented rings. But motor still runs, but won't do to use it. Pretty much dead in water.
