1985 Yamaha 50ETLK outboard question
choo
Hoping someone can help, I bought this 1985 Pro Craft bass boat last year, engine hard is hard to start when cold. My main question is I have been all over the internet trying to find a manual for the motor. 1985 Yamaha 50ETLK. seems no one offers it, even go to Yamaha web site. Closes one I could fine is for a 50ETLJ which is i year newer. Please, any suggestions would be greatly appreciated. Thanks, Jim
boscoe99
The 1986 manual will work for your model motor.
Regarding a cold hard start, is the choke plate closing when the key is pushed in or the choke toggle switch is pressed?
choo
Ok, thanks. Ill order the 1986 manual. The issue I am having is there is no way to turn the choke half off. Yes, the plates are closing, starts stalling out, I turn choke off, then the plates opens wide again and get it too lean on a cold engine, dies before it catches again. wish I could turn choke half off like on a chain saw or trimmer or like most 2 cycle engines. Main thing is it is embarrassing at the boat dock. lol I ordered cooling muffs so I can play with it at home a little bit. thanks so much for your input.
99yam40
most people just bump it a little when needed during warm up, not just turn it on or off
boscoe99
Maybe try advancing the throttle just a tad while leaving the choke plate fully closed. Different motors seem to like different starting procedures for some reason. Finding the right one can be fiddly.
I bought a pressure washer with a Honda motor. Try as I might it simply would not start using the published starting procedures. My Honda generator starts quite well with the throttle wide open and the choke fully engaged. So I tried that on the pressure washer motor. Works like a charm.
