1985 Mariner 40EL doesnt pee much water when throttle up
ZLAVY
My outboard will shoot a decent stream out of the pee hole at an idle, when I throttle up it becomes less of a stream of water and more of a sputter of water coming out? I dropped the lower end and took a look at the impeller and water pump. everything looked fine. Should I go ahead an replace the impeller or would something else cause this?
