1985 johnson vro 70hp no fuel
jcorkin
I just bought a pontoon boat and it came with an extra bigger engine and I swapped it on to it. Upon trying to start it I found that it would only run if I sprayed premix into the carbs. I then opened the bowl drain screw and no fuel came out. I can pump the primer bulb until it gets hard and I still get no fuel to the bowls. Any ideas on what could be causing the blockage? I started pulling the pump off so I can open it up and take a look inside but want to get some more info before tearing into it. I dont think all 3 carbs could have the floats stopped up, but I guess it is possible.
Daviet
Remove the fuel hoses going to the carbs and pump the primer bulb. If you get fuel out of the hoses your problem is in the carbs, probably stuck needle and seat.
jcorkin
Thanks for the advice. I went out and pulled the main line running to all 3 carbs and tired priming again. Got it to push out fuel and some nasty debris. I pumped it several times to make sure all the debris was out and hooked the line back up. Primed it up and the carbs filled up. She is running like a top. I also cleaned out the fuel filter on it as it had a decent amount of debris in it. Im wondering if any of this had to do with me transporting it on its side to get it back to my house when I got the boat? Anyways she is up and running great, thanks for the recommendation.
