1985 Force 125 Power Trim Valve diagram
coavs52
I had the shuttle valve located at the bottom of the valve body shoot out on me yesterday when I left the lake, I think I found all the pieces (hex shaped check, spring, aluminum end, snap ring). I was wondering if there was a breakdown of the Valve available. I have looked all over and can only find the breakdown of the tilt assembly. I don't want to purchase one of the new weak ones, just wanted to re-assemble this one. Can anyone help??
Thanks
pnwboat
Re: 1985 Force 125 Power Trim Valve diagram
Here are some pictures of the check valve. The parts are layed out in the order that they come apart in the second picture. Also be aware that there is a small rubber seal on the end of the hex shaped check valve. It goes on the end that has the small nipple. Very important seal to prevent leak down. Pay close attention to RRit's comments on the link. Good advice.
http://forums.iboats.com/showthread.php?t=418734&highlight=tilt+trim+check+valve
coavs52
Thanks! exactly what i needed.
