1985 Evinrude 150 Head Replacment
wehrlzz77
Currently working on a 1985 Evinrude 150 (E150STLCOH 1985), and i recently found out that the STBD head needs replacement. I have a line on parts from a running 1988 Johnson 150 (J150TLCCA 1988). Will the cylinder heads from this engine work with my 1985? I believe it will bolt up no problem but I'm no expert on compression numbers. Its either this or i but a new cylinder head from ebay.
Thanks in advance for any input!
Joe Reeves
There's a part number on the head (raised numbers), usually in small numbers somewhere near the top portion in circular form. What is that number?
James R
The part numbers for the two years are not the same. That doesn't mean that it wont fit. OMC had a habit of making minor changes and the part numbers changed accordingly. The part number you need is 329773. Try Ebay for that number.
