1985 Evinrude 120 trim delayed engage
kmarston
When i hit the trim up, it takes 35-40 seconds for it to engage...any suggestions what to check first???
Hooty
Re: 1985 Evinrude 120 trim delayed engage
Look for low hydraulic fluid or air in the system.<br /><br />c/6<br /><br />Hooty
jarob
This posting may help<br />--------------------------------------------------------------------------------<br />Jarob...... That problem is caused by one of two ball bearing type check valves that are located in the oil pump which is located under the electric motor. The cure is to replace the oil pump.<br /><br />However, this is something one can live with. It's simply a matter of waiting approximately 60 seconds after raising or lowering the engine to its extreme/max position.<br /><br />--------------------<br />Joe (30+ Years With OMC)
