1985 8 hp Johnson 2 stroke will crank but wont start
pbcesare
Bought this and it wont start. Inspected the fuel lines for a blockage and the carb is getting fuel. Has new spark plugs but haven't tested the compression. It looks like it was well taken care off in regards to the internal components so i feel like its something small. I may try to clean the carb I suppose and see what happens?
S/N J8RCOB
oldboat1
New spark plugs doesn't mean there is spark produced -- need to test ignition with an adjustable spark tester (cheap little tool). Stop or cutoff switch?
pbcesare
Also I dont really know much about the stop switch. I tried cranking it in all positions the knob would turn
oldboat1
Some motors have a kill switch (man overboard switch) -- red button, typically, with a clip and lanyard. Your '85 MAY have a kill switch in the tiller handle, at the end. It's probably meant to be depressed to stop the motor (shorts the ignition). In the case of a button, the circuit is open unless you press the button, shorting the ignition. If it fails with the circuit closed, the motor will not fire.
If you have the push button, you might try spraying it with a little wd-40 and operating it just in case it's sticking -- try to free it up. If the button/switch is defective, it would have to be disassembled. One of the leads usually goes to the power pack, and another to a mounting bolt for one of the coils (ground point). There may be a single line connector at the rear of the powerhead for the wire leading to the power pack. Disconnecting the wire would defeat the kill switch, if it's a problem.
Someone who has your particular motor might jump in here with added info. and advice.
flyingscott
Pretty sure you have a kill switch in your tiller. Take a zip tie and pull out on the center of the button then use the zip tie to hold it out. If it starts you may need to use the choke to kill the motor. Then order the clip and lanyard and leave the zip tie loose so you can cut it off.
pbcesare
There doesnt seem to be a kil switch but I believe i figure out what the problem is. The whole damn power pack is missing... F me
