1985 150hp xr2 will not stay running at idol speeds
donovan64
I have a 1985 150 hp xr2 it will not run at idol speeds I have cleaned the carbs, installed new fuel lines and water fuel separator, mech did a link and sync adjusted low idol timing, I am running 90 non ethanol with a 50 to 1 mix cleaned the fuel pump. Any ideas mech leaning towards reed valves
Re: 1985 150hp xr2 will not stay running at idol speeds
Reed valves should have been looked at when carburetors were off.-----------------What are the results of a compression test ?
James R
Check the sparks very carefully. These motor are susceptible to power pack failure when they get old. Very rare to have reed problems.
wired247
How did he adjust the idle timing if it wont stay running at idle?
Faztbullet
Need a little more info on problem....
quicktach
You didn't mention a straight fuel filter ahead of the carbs ...in addition to a water/fuel separator. Is the gas filter clean ?
adam98
I went nuts with that motor with a lot of running issues.... And after 4 carb rebuilds and much frustration going through everything I could think of ..multiple times. I ordered the complete gaskets kits for each carb and fix all my issues. Maybe $25 each carb. Mine is an xr4 But this race or high performance type motor does not have a super smooth idle. But above that it screams.
adam98
Old gaskets looked fine but don't hold enough or steady vacuum at idle to get fuel all the way up to the upper idle circuits on top of carbs.
