1985 120hp Loop Charged Evinrude carb kits
Luna Sea
Hi Guys,<br />Some good links in that carb rebuild post. I'm trying to order the carb rebuild kit for my 1985 120hp (EL120TLCO) Loop Charged Evinrude. Trying to save a few bucks since I'm ordering 4 of them here so here's what I've got:<br /><br />Maxrules.com $18.00 p/n 439078<br />Boaterssupply.com $17.22 p/n 0439078<br />These 2 sites clearly point me to the same kit<br /><br />However,<br />Outboardparts.com $13.50 p/n 2634, points to <br /><br />OMC Carb Kit no. 2364 OE 435752, this is a totally different number but the site says it's for a 85-87 120 Looper. Is this just a partial kit? Should I go with one of the others?<br />Or can I save $20 here? :rolleyes:
rickdb1boat
Re: 1985 120hp Loop Charged Evinrude carb kits
Luna, they are the same kit.
Luna Sea
Thanks again Rick!<br /><br />So kit 435752 is the same as 439078? Thought maybe one kit had more parts or something. Guess none of the kits come with float, needle valve, ect. Tried to post this in a way that anyone else searching for rebuild kit would find this, and maybe save $20 too.<br /><br />Happy Holidays
rickdb1boat
(878951)= 435676, 435677, 435678, 435752, 437327, 439078, 439079 Carburetor Kit. All the same! Looking at the parts included, I don't see any difference.
93bronco
Ensign
i just went through that and there is one kit that has everything for multi-year carbs that was #439078 @ 18.25 here. the one i got was #439079 @ 15.35. that has everything <float,needle&seat,side,bowl and base gaskets> that one fit my 1985 140 carbs and my 1988 120 carbs. hope that helps
Dhadley
Most are basically the same except there are two different size O rings (carb body to throttle body) for the large and smaller carb venturi. Then there are the different style side plates.<br /><br />Good luck!
