1984 ? Merc 115 with a JET--Running the jet in the driveway to test ?
ab59
Ensign
Howdy all , I just bought a 115 hp Merc with a jet on it . I bought it for the jet and was going to use the motor for parts as I was looking at another 115 as my runner.I would like to try and run the motor and then run a compression test . I have a flushing tool that screws into the water system somewhere around where the jet is bolted on. I can not seem to locate the stainless steel bolt head that is supposed to be there that is removed to screw in the flushing nipple .
Please remember that this is a JET not a prop . I have surfed the net and found information about the flushing hole bolt but there does not seem to be one on this motor. What am I doing wrong ??? see pics.
ab59
Ensign
Alright , since once again I get no advise , I will answer my own question to that someone else might benifit from what I have found. There is no port to run water through the jet on the midsection or the jet itself. So in finding this out I began to take the jet off as I also have the prop lower . I stopped before I got it all the way off and talked to the guy that I bought the motor from and he simply said that he had removed the jet and attached a water hose to the water tube intake . Easy enough and now that I have finished grouting the tile I just laid in the front bathroom I will have a couple of days to get back on it. On to the compression test results.new topic
Texasmark
Nothing personal, just the courtesy that those of us who don't know...and apparently all of us, don't blow smoke up your ........
