1984 Johnson 60hp compression reading after sitting several years.
spetzs
I just traded for a 76 Starcraft super sport 16' with a Johnson 60HP motor, boat is a total restore project. Motor was super clean but had been sitting for 3 years. Before I invested any money into it I wanted to check the compression. The motor tested at 95 PSI on both cylinders after doing nothing to it, my first thought is this may be fine as it has sat for a long time and was cold. Thoughts?
Honorary Supreme Mariner
My compression tester routinely shows 145 / 150 psi on those motors.--------3 years is not very long for a motor to sit.-------Try another gauge first !
wrench 3
If it hasn't had fuel oil mix through it for three years the cylinders are probably dry and the rings won't seal properly. Get it to fire up as cheap as possible and then recheck the compression. Or you could oil up the cylinders, but that might give you a false high reading.
If they're both even that's a good sign anyway.
boobie
Get it to run, do a good de-carb on it and then check the compression.
humleridder
I would put some oil through the spark plug holes and test again. Lubrication is usually always a good thing. If possible test with another tester as suggested. Consider that it could be a good sign that they test to similar values. If both cylinders are broken - they are evenly broken when it comes to compression... maybe the odds are higher that your gauge is not calibrated correctly. Just my thoughts on why to keep your hopes up a bit further.
