Hello to everyone! I am new to the site. I am also a new boat owner. I purchased a project boat that I just could not refuse lol..It is a 16 1/2 footer all fiberglass with trailer and 1984 Force 85hp outboard for $400...When I purchased the boat the motor would turn over but not fire. I have fixed that problem and now have the motor running (stator was bad). After getting the motor to run I noticed no water was exiting the holes in the rear of the outboard. I turned the motor off and allowed to cool completely while I wondered what the problem could be. I started the motor up again and still no water was flowing. I removed the thermostat which had corrosion all over it and some corrosion was visible in the power head. I replaced the thermostat and gasket. Also since I noticed no water was at the thermostat I removed the lower portion of the outboard to replace the water pump assembly. I noticed that the impeller appeared to look just as good as the new one I was replacing it with. This concerned me so I inspected the water tube going up to the power head. I used a long very thin wire brush and slowly ran up the tube and removed with no dirt or corrosion on the brush. I then used compressed air and blew into the tube and did have a slight bit of air at the power head where the thermostat was removed from but not enough air like I should have or think I should have. I went ahead and put the new water pump assembly and new impeller on and reassembled. I still have no water flow. I have tested with a water hose using the "mickey mouse ears" and also tested with a large plastic bin with lower leg submerged both with no success. What else could be my problem and what steps should I take next? I did purchase the manual for the motor and that was worth it to help with the stator, trigger, coil, etc testing that allowed me to get the motor running. I am new to boats and boat motors but have worked on cars, trucks and motorcycles for some time now.
Thank you in advance for your time and assistance.
Josh
Josh
