I have a 1984 70hp evinrude that starts and runs great while on the muffs but it will not start in the water. I have had someone suggest that it might be a bad head gasket or low compression. i know that the lower oil seal on the lower unit is bad. Could this cause my problem. <br /> I have not had this motor very long. Right after I got the motor I took it ou for a test run. It started O.K. in the water then, however, after running it for about a mile I decided everything was fine and throttled back to turn around. When I went to throttle back up the motor bodded down and eventually died and would not restart. I had to paddle back to the boat ramp. <br /> I have rebuilt the carbs. Replaced all the fuel lines and fuel tank. It will pur like a kitten on the muffs but like I said now it wont start in the water.
