rooster519
- May 28, 2011
- 12
I'm about to give up on this motor. I replaced the switchbox, checked all electrical connections, cleaned the carb and rebuilt the fuel pump. If the motor sits for a day or two it will fire right up and run for about 15 seconds then die. It is like the motor is flooding itself. The gas is new (as of a month ago) so I don't think water could be the problem. I have great spark on both cylinders. When I'm priming the motor the squeeze bulb never get's hard but I do see fuel in the carb and I can get fuel to spray out of the bowl over flow. The motor spins freely without the spark plugs in and compression seems normal when spinning by hand, however, I have not done a compression test on the cylinders. The fact that it runs for a couple seconds makes me think that compression shouldn't be the problem. Any ideas??? Thanks for all your help!!!!
