1983 Mercury 70hp Stator/trigger orientation and missing trim tab
Dropshot Fool
I bought an '83 Mercury 70hp to repower my boat but the stator and trigger were missing. Ordered new ones and want to install them, but not 100% sure which orientation to install them. The service manual I downloaded doesn't show this clearly. Anybody got some advice for me?
Also, there is no trim tab on the motor. I believe this is required but I'm not sure how to go about selecting the right one?
Thanks.
Dropshot Fool
Ok, I think I have it figured out. The trigger rests inside the frame on top of the motor, upside down with both the trigger "finger" and the wires through the "windows". The stator goes over top of it, nested and clocked so that the slight protrusion on it where the wires exit is down and directly facing the starboard side. Could someone confirm?
I have the wiring mostly understood. The black from the stator and the trigger both go to ground? I'm not sure where to ground the trigger to?
In addition, the wiring diagram for this motor shows green/white from the CDI to #2 coil and green/red to #3 coil. This motor is wired opposite? Why would this be wired like this and would it have damaged the motor?
Thanks again.
Texasmark
I can help with some of it.
I guess you figured out the up down orientation and the wiring goes out the starboard side as that's where the electronics are located.
Solid black wires route through the engine powerhead where the battery - is usually attached....If it's black, it is ground (batt -).
All the CDI's perform the same function. Only question is which cylinder is "ready to be fired" when the trigger gets to it. I don't have the wiring diagram but you can figure it out. Plug them up and if the engine idles smoothly (675 rpm range) and takes the throttle easily, you can pretty much figure you got them right. If not, swap leads till it happens. That's how I used to trouble shoot.
Edit: The 675 number is in the water, moving forward in F gear (repair manual number). In N it would rise up to maybe 800 give or take.
If you don't have steering torque problems (turn loose of the wheel and the boat veers to one side or the other}, you don't need a trim tab. If yours is missing, may be that it's not an issue. Smaller hp engines don't have them for that reason.....Mercs anyway.
Trim tabs are readily accessible and just look for the one that fits your lower unit/engine series; usually specified in the www ad. You'll need a hex socket stainless steel bolt to mount it. When installing, start with it straight out and if you get some steering torque, turn the rear of the tab in the direction the boat turns. Obviously, the more that it's off center, the firmer the response.
