1983 Johnson 2 stroke Johnson bogging down on acceleration.
blakevw
I have a 1983, 2 stroke seahorse johnson that dies if I put the hammer down, especially if I drive at idle for a minute or 2. If I choke it out for a few seconds then take off there is a lag for 1 second, but then it seems to take off fine.
I have checked the fuel pump, it is in great shape, cleaned the carbs by filling the float bowls with carb cleaner and running and letting sit, starts up just fine, idles fine, when it is running full out it also seems to running fine.
Any suggestions?
thanks in advance
gm280
Okay where do I start? :noidea:
First, you don't "clean a carb" by filling the fuel bowl with carb cleaner and running it. You remove the carb(s) and buy a rebuild kit for that carb and disassemble it and clean each and every part perfectly clean. There are different areas or systems in a carb. One is for choking, another one for running at idle and then still another system for running at high speed. So each circuit has to be cleaned and re-assembled again with new gaskets and items that come in the carb kit. With that said, have you tested to see what the compression is on each cylinder? Those compression numbers would tell you the condition of your engine. Also again, looking at the fuel pump doesn't verify that it is working properly. You have to remove the fuel line coming out of the pump and then crank over the engine to see the fuel flow coming out of it. Use a collection container to capture the fuel when testing it. The stream of fuel will determine the condition of the pump. If it is merely trickling out, you need to either rebuild it as well or buy a new one, your option. Once you accomplish all those things, post your compression results here for us to see. JMHO!
James R
Right on gm280. A rebuilt pump may still be a problem. A new one is the way to go, they are not expensive, unless you have a VRO then rebuild the fuel side. I usually throw the VROs out and use standard pumps with 50:1 mix.
oldboat1
You may have a bad pump diaphragm. Fuel pump will run $50 to $90 for, say, a 50 or 60hp. A rebuild kit is $12 to $15 -- post your model number/hp.
A standard test along with the one gm280 describes is to pump the primer bulb when the motor is acting up. If that resolves the problem, there is a good chance it's a fuel pump issue. From your description, I would guess carbs offhand, but just a guess (agree with gm280 re. proper rebuilding).
blakevw
gm280, its nice to have someone commenting who obviously knows everything, thank you for setting me straight. I typically like to try the simplest solution first, call me crazy...
oldboat1 I tried pumping the bulb, it didn't solve the issue, I should have mentioned that. I haven't tested the compression, but the motor stars up from cold without an issue, which may indicate the compression is good. I will test it however, I understand that can make the fuel pump act up.
I plan on taking the carbs off and taking them apart this weekend. I will post the results.
Just as an added piece of info, filling the bowls up with carb cleaner and running the motor seemed to make the engine run better. I'm thinking now it's dirty jets.
The motor is an '83 70hp, 3 stroke Johnson. I don't have the model number, sorry.
