1983 force 125hp gear plug drain Pn and fill/vent washer
sanjaykp
trying to find part numbers for gear drain on a 125hp gear lube drain. I have looked at posted comments and there is apparently 3 sizes. This is the drain on the bottom the bullett and mine is a flathead. I would also need the part numbers for the o-ring for the drain, vent and fill. they are not listed on the parts diagrams I have seen. any help would be appreciated
thanks
bentle
Re: 1983 force 125hp gear plug drain Pn and fill/vent washer
Boats.net has alot of specs. for force outboards.
jerryjerry05
Any american outboard or sterndrive will use the slotted screw.The gasket is plastic(no good) or a fiber gasket (good and re-usable).Some Forces used an allen head plug(leaks) that needs sealing tape.
Force used to use plastic crush washers,usually good the first time.Should not re-use.
Any boat sales selling american made products will have the plug and seal.
Jap motors have a smaller size.
Fill out the profile.You might be close to someone who can help.
