1983 evinrude 75 hp
Cwbrown10
I'm having issues with the motor wanting to shut down when I put it into gear. Or going to load it on the trailer if I try to push it further on it cuts off every time. Once it gets on pad the motor runs perfect. It's only in low idle situations. This weekend I noticed 2 or 3 times when I shifted it to neutral it would rev real high and I would shut it off with the switch. It has 3 carburetors I pulled the top one and It seemed really clean. It didn't have any varnish in the bowl or anything like that. Any suggestions? Thanks
Honorary Supreme Mariner
The 2 most important checks are # 1----Compression , post your numbers.---# 2 is a spark test ---Does spark jump a gap of 7/16" on all 3 leads , yes or no ?
