CApTaInGoOfy
Thread starter- Joined
- Aug 17, 2015
- 91
So I finally got my boat out on the water yesterday, and it ran good, at least that's what I think. I was surprised on how quiet the motor was at idle in the water. I thought the motor shut off. After running it out of the no wake zone, I increased my speed until eventually I was WOT. I was zipping along the bay, and came to a stop b/c the kids wanted to see the birds that were nesting.
I cut off the engine and we drifted for a couple minutes, then went to start the motor & it wasn't starting. It was turning over and sounded like it wanted to start but would not. I had to almost put the shifter to almost WOT for it to start even at WOT position it needed a couple attempts for it to start. At this point I was on the water for possibly 10 minutes. I then started to head back to the boat ramp.
When I got near the ramp, my curiosity got the best of me, so I cut the engine off again, and waited roughly 15 minutes before trying to start it again. I had to do the same thing again, for it to start. Play with the shifter position between neutral & WOT (both times I had the button pulled out). Headed back to the ramp, and at the ramp the motor cut off on me, after I shifted from reverse to neutral.
Packed the boat,kids,wife & gear up & drove home. At home when I flushed the motor it fired right up first try...
Any thoughts/info would be greatly appreciated.
Info:
1983 Chrysler 45hp
Model: 457H3P
Serial: 1322
These are the only things that I have done on the motor since purchase:
Lower unit oil changed (Mercury SAE 90)
Lower unit seals replaced (Except shift rod seal;not sure how to do this one)
Info:
1983 Chrysler 45hp
Model: 457H3P
Serial: 1322
