1983 40horse wont start on its own but will starting fluid help
Ayuh,.... Welcome Aboard,.... Are ya primin' the carbs with the fuel bulb,..??
Are ya Chokin' it when crankin' it over,..??
Are ya givin' it some throttle,..??
not fishing yet
yes I pump the blub and gas come threw the carb put new gas in checked everything I think started fine a week ago
Silvertip
You didn't answer the "choke" question nor did you mention use of the "fast idle" lever. Choke = push in on the key while cranking. Fast idle lever is the lever on top of the control box that lets the engine idle faster while in neutral.
