1982 XR2 throttle cable install help needed ASAP
ChrisD2725
Where does the throttle cam return spring attach? parts catalog show the attachment to the throttle cam itself but not the other end.
Thanks
Chris
Dukedog
??? throttle cam return spring??? only "spring" i know of is tha big one between throttle arm and timing arm.. has nothing ta do with "cam"?
part number of you're lookin' at....
Dukedog
all parts sites i've got show invalid part number??? but is it half moon kinda shaped large spring that has a "tang" on both ends?.. if so tha tangs go in two holes.. onein tha block and one in tha throttle arm assem.. its installed when complete timing/throttle arm is installed with tha 3/8" bolt....
GA_Boater
The part number is 24-2977. Beats me where it hooks up.
Dukedog
looking at your drawing.. tha 90* tang on tha right fits a 1/8" hole in tha block..tha 90* tang on tha left fits a 1/8" hole in tha arm assembly. (lower or throttle part) it has to be installed as tha complete (both pieces) throttle, timing arm is installed with tha 3/8" bolt.... it pre-loads tha assembly ta keep pressure towards idle, against 1/4" idle stop screw....
