1982 Mercury 70hp starter problems
Brian_
I tried to start my boat the other day while launching and the cranking battery was dead. I switched to a trolling battery and evidently reversed the polarity when I hooked the battery up because the starter made a whizzing sound and would not engage (assume it was spinning backwards). I corrected this and she fired right up and hours later I just got a click when i tried to start again. I removed the starter and took it apart and a couple strands from the brushes had broken off and also fallen into the bottom so i dumped those out and put the starter back together. I hook it back up and it's now spinning backwards but i'm fairly confident the polarity is correct from the battery. I also replaced the solenoid is there anything else that could cause the starter to spin in reverse other than polarity reversed at the battery? Now when I switch it at the battery the starter will engage just fine but i'm almost positive this isn't correct.
MH Hawker
Re: 1982 Mercury 70hp starter problems
Trace out the wire that runs from the starter solenoid back to the battery, it should be on the positive terminal. Any thing else is wrong.
Brian_
Turns out when I took the starter apart i put the housing in upside down. Problem solved now and i didn't have to buy a new starter yet!!
