1982 Johnson 115 starting and idling problems
LAW0412
Motor hard to start. Have to take callen off and use choke. Idles about 60 seconds, then dies. Cranks right up. Runs great. Fish for about an hour and same staring problems occur. This is the second motor on the smae boat. The other motor was an Evinrude 150, 1988 model. I had the exact same problems with the 'rude. Have had carbs cleaned and adjusted. any suggestions?
petryshyn
Re: 1982 Johnson 115 starting and idling problems
Are you using the warm-up lever?<br /><br />Are you squeezing the primer ball till hard, then pushing the key in for 10 seconds before cranking a cold engine?<br /><br />Sometimes you have to nurse it with the key to keep her running that crucial few seconds....
