Re: 1982 Evinrude 75hp
If this problem started after changing the water pump, I would have a closer look at the seal below the water pump. Increased water pressure from pump and a bad seal - quite a common problem. Do a pressure and vacuum test of the gear housing, that might give you the answer. When testing, the best is to remove the gearcase and water pump and rotate both shafts during testing.
